Cotten magneto for KZ1000?
  • hangedk
  • hangedk's Avatar Topic Author
01 Nov 2013 23:12
#611880
Hey everybody. I found a cotten magneto for the KZ1000 today, but it might need a little tlc. I've never come across magneto setups like this in person and don't know the pros and cons of them. But the combination of getting rid of the heavy old battery and the cool factor of having an old school magneto setup is kind of drawing me in. Can I get new caps, rotors, belts, etc for these anymore? Should I try to get it?
  • wolfey
  • wolfey's Avatar
Re: Cotten magneto for KZ1000?
02 Nov 2013 11:38
#611898
could u post pics of the cap and rotor and see if theres a tag on the mag itself my experience with mags is if it will click then put points and a condenser clean the cap but it looks awesome
building something is better then just buying someone elses blood sweat and tears
  • turboking
  • turboking's Avatar
02 Nov 2013 12:54
#611905
:unsure: just so you know there is no mechanical advancer on this type of magneto.... :pinch: made for the dragstrip or racing :blink: ..... what ever timing you set it at is what you get..... cool , yes but belt , points and condensers need replacing along with the cap and coil . cotten mag's were sold in the early 70's .... can't say on availability of replacement parts. probably belts are the same for all mags of this type.... points are probably off some early 70's honda :pinch: IMO, Dyna S or a dyna 2000 is a better deal for the street..... :S set it and forget it
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • hangedk
02 Nov 2013 13:48
#611907
I couldn't get any pictures from the seller that were clear enough to tell. But he seems to think that it needs a new cap.
wolfey wrote: could u post pics of the cap and rotor and see if theres a tag on the mag itself my experience with mags is if it will click then put points and a condenser clean the cap but it looks awesome
  • hangedk
02 Nov 2013 13:50
#611908
All right, that makes sense. I agree totally on the dyna systems. I just thought this thing was super cool, and a good conversation piece even if I don't run it.
turboking wrote: :unsure: just so you know there is no mechanical advancer on this type of magneto.... :pinch: made for the dragstrip or racing :blink: ..... what ever timing you set it at is what you get..... cool , yes but belt , points and condensers need replacing along with the cap and coil . cotten mag's were sold in the early 70's .... can't say on availability of replacement parts. probably belts are the same for all mags of this type.... points are probably off some early 70's honda :pinch: IMO, Dyna S or a dyna 2000 is a better deal for the street..... :S set it and forget it
