LI batteries Worth iT?
  • bountyhunter
  • bountyhunter's Avatar Topic Author
01 Nov 2013 13:53
#611839
My battery is getting tired and so I need to decide what type to get. The AGM are good, but filling with acid is a hassle. The Li batteries are attractive (but expensive) but my concern is on reliability. I have read a bunch of posts where they failed very quickly and some where they don't crank well when cold.
Is anybody using the Lis and what brand is best?
  • 0Z.Z1R Mk2
  • 0Z.Z1R Mk2's Avatar
Re: LI batteries Worth iT?
01 Nov 2013 15:56 - 01 Nov 2013 15:57
#611843
Absolutely....thoroughly recommend them.
They are very light and powerful..
Choose a good brand like Shorai and I recommend you buy a balance charger to suit.
www.amazon.com/Shorai-Battery-Management...-BMS01/dp/B0056J2ZGC
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
Last edit: 01 Nov 2013 15:57 by 0Z.Z1R Mk2.
  • dadgonebroke
  • dadgonebroke's Avatar
01 Nov 2013 17:15
#611848
I have four bikes and have Shorai's in two with no issue- especially since I replaced the regulator/rectifiers with the new style units from Z1 Enterprises.
  • bountyhunter
01 Nov 2013 20:31
#611867
dadgonebroke wrote: I have four bikes and have Shorai's in two with no issue- especially since I replaced the regulator/rectifiers with the new style units from Z1 Enterprises.
Which regulator?
That was my concern. Li batteries are very critical about charge voltage.
  • RonKZ650
  • RonKZ650's Avatar
01 Nov 2013 22:08
#611875
Last battery I bought was a Motobatt AGM made in China of course like all the rest. I've had it coming up on 3yrs now in one of the KZ650s which I actually ride once in a blue moon. It sits for a couple months sometimes, sits in 10 below zero, 100 or more above zero and when I go to start the 650 which is a real joy, the battery will turn the starter every time great for the 2 or 3 minutes it takes to start. I'll say this is the strongest battery I ever had and it's cheap by comparison and life is looking to be good too.
