Headlight dosen't work
- newoldride
31 Oct 2013 16:02
everything works on this bike but the headlight won't come on.The bike is a 1979 kz1000 ltd the bulb is good any suggestions
- 4TheKZ1000
Re: Headlight dosen't work
31 Oct 2013 16:29 - 31 Oct 2013 16:35
check for ground and power at pigtail. power is red/yellow and red/black.
should be 12v +
ck blue might be other color wire at fuse box......10 amp fuse
should be 12v +
Last edit: 31 Oct 2013 16:35 by 4TheKZ1000.
- Beaner242
31 Oct 2013 17:27
Blue and yellow feed my headlamp switch. Yellow and red are low beam. And red and black are high beam. If I remember correctly. Not always the case these days though.
1982 KZ1000K LTD Chopper
- MFolks
31 Oct 2013 19:16
Print these out, and keep in the toolbox:
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
HEADLIGHT
- newoldride
01 Nov 2013 09:03
Thanks for all the help it ended up being that someone put a switch behind the left side cover don't know why it was put there but I found it thanks for all the help and I will keep the wire color codes
The following user(s) said Thank You: 4TheKZ1000
- 4TheKZ1000
01 Nov 2013 11:29 - 01 Nov 2013 11:34
some people like to ride without a headlight during the day? never understood it but I know of three that do. I have a switch on right control called PO that I can turn on and off headlight. I ride with it on.
It might have had a charging issue at one time or another and owner didn't want to use headlight.....who knows. Kind of strange that the switch was hidden under cover that you couldn't get to while riding???
glad your in the wind again safely......
Last edit: 01 Nov 2013 11:34 by 4TheKZ1000.
- bountyhunter
01 Nov 2013 13:50 - 01 Nov 2013 13:50Maybe switch for turning the headlight off when starting the bike? That extra load at starter crank really shortens the battery life. I use a relay to disconnect the lights automatically when starting.4TheKZ1000 wrote: some people like to ride without a headlight during the day? never understood it but I know of three that do. I have a switch on right control called PO that I can turn on and off headlight. I ride with it on.
Last edit: 01 Nov 2013 13:50 by bountyhunter.
