440 A2 No spark
- kz700rider
30 Oct 2013 14:57 #611636
by kz700rider
440 A2 No spark was created by kz700rider
no spark while i engage the starter but have a spark when i touch a scewdriver to the pickup coil. Any quick thoughts? Im stumped. Any help would be greatly appreciated.
- Cynjut
- Thank you received: 26
31 Oct 2013 07:29 #611692
by Cynjut
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
Replied by Cynjut on topic 440 A2 No spark
First guess - Marginal battery.
Second guess - Marginal coil.
Third guess - bad points or condenser.
1977 KZ-1000 A1
- kz700rider
31 Oct 2013 09:04 #611703
by kz700rider
Replied by kz700rider on topic 440 A2 No spark
It has a new charged battery and its electronic ignition. So that means no .points. i'm getting a spark and primary winding on the ignition coil has correct resistance but the secondary winding has nothing. Then how am I getting a spark?
- Cynjut
31 Oct 2013 09:19 #611705
by Cynjut
1977 KZ-1000 A1
Follow the procedure in this:
www.mpsracing.com/instructions/Dynatek/DynaS_Testing.pdf
The resistance on the secondary should be MUCH higher than the primary - if the primary is 3 ohms, the secondary should be well over 10K ohms. The table in the PDF is a good indication for Dyna coils, but may vary some with other manufacturers.
1977 KZ-1000 A1
- kz700rider
07 Nov 2013 16:35 #612357
by kz700rider
Stupid me. When I turned the engine over manually with the false nut, I must have bent the pick up coil out of place with the wrench. I carefully bent it back then had a spark then a running engine. At least it was a cheap fix. Thanks for all the replys
