Need ARD Mag help
- Mercury Kid
Need ARD Mag help
26 Oct 2013 05:35
Started screwing with the ARD mag on my Z1 chopper yesterday with mixed results. I swapped the point for a Honda 350 point which is an exact match, and tried a couple different condensers, including the original, but still have very weak spark. I had high hopes, since all signs point to this unit never actually being used, but I think it needs a new coil I can't find anything about these anywhere. There is a thread on the sohc honda forum that I read quite a bit of but still didn't see anything about where to get parts. Any help please?
I added a pic for reference, and already emailed Joe Hunt Mags
Attachment IMG_0381.JPG not found
Attachment IMG_0383.JPG not found
'76 KZ900-Z1 clone
Z1 70's period longbike
- Motor Head
Re: Need ARD Mag help
26 Oct 2013 08:10
APE JAY posted this quite a while back in another thread and it was found to be a good contact back then. Not sure about now, but worth a try.
ARD Engineering
10628 Norwalk Blvd.
Santa Fe Springs Ca. 90670
Phone 562-941-5842
ARD Engineering
10628 Norwalk Blvd.
Phone 562-941-5842
- kzz1king
26 Oct 2013 14:49
I would visit over at dragbike.com and check out the forum there.. I an sure there are guys over there that have used these.
Wayne
Wayne
Home built KZ1000 turbo setup
- Mercury Kid
26 Oct 2013 16:31
The number is disconnected. Google'd them and got another number from a pdf of instructions from the honda forum again, that number is bad too. Also found magnetoparts.com, his number is connected, so I'll try there next, but I'll look into the dragbike forum, thanks.
'76 KZ900-Z1 clone
- Mercury Kid
30 Dec 2013 05:42
Found out that the cap and rotor are Fiat 600 parts, still looking for a coil and a belt.
'76 KZ900-Z1 clone
- turboking
30 Dec 2013 07:39
sounds like a bad coil as you stated....... :S good luck in you parts search
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
