Anybody Try White LED BA9S for Instrument Lights?
- bountyhunter
19 Oct 2013 03:33
If I have to go through the PITA of changing all the instrument bulbs.... would rather install something that doesn't go dim with age.
Anybody using any of the new white LED drop ins?
Saw lots out there, have no idea which are any good.
www.superbrightleds.com/moreinfo/led-veh...ajoroCFe01QgodtzgAoA
www.amazon.com/BA9S-Light-Bulb-Round-White/dp/B005WYH1RE
www.google.com/imgres?imgurl=http://cdn6...hYAI&ved=0CFQQ9QEwBg
Re: Anybody Try White LED BA9S for Instrument Lights?
19 Oct 2013 15:51
I posted this link in your other topic as well - it has LED alternatives - see replies by guitargeek.
Instrument panel bulbs - Eiko alternative?
- bountyhunter
19 Oct 2013 16:22
Thanks, they do look pretty good.
- MTH76
22 Oct 2013 13:03
I used white LED bulbs in the guages and a green one in the neutral indicator.
I put a blue one in the high beam indicator, it is a little too bright at night.
The guages light up much better at night!!!
Like you said, it is such a pain to get to them you might as well do it now.
1976 KZ900 1075 head ported,over-sized intake valves shim under bucket Z-4 cam motion cams 34mm RS carbs back cut trans GS1000 swing arm with 3.5" Sun rim MotoGPwerks stainless steel pipe
- bountyhunter
22 Oct 2013 16:28Which kind did you use for the colored lights for the center indicators?MTH76 wrote: I used white LED bulbs in the guages and a green one in the neutral indicator.
The high power ones that put out 25 lumens only come in white.
I was thinking it would be better to use red, green or blue LEDs for the indicators since that is the lens colors used in each case, but the SUPERBRIGHTS that come in colors only put out 7 lumens which is pretty weak.
- MTH76
23 Oct 2013 13:55
It has been almost a year since I changed them, I got them off of E-Bay.
Type in BA9S LED bulb, you will find alot of them.
- bountyhunter
23 Oct 2013 16:37 - 23 Oct 2013 16:38OK. That's the problem, I saw tons of lights on ebay but many people have posted that a lot of them are junk. I wanted to stick with what people have actually used and know they are bright enough to be seen outside.MTH76 wrote: It has been almost a year since I changed them, I got them off of E-Bay.
Last edit: 23 Oct 2013 16:38 by bountyhunter.
- guitargeek
23 Oct 2013 21:04
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
