How to install a starter
- prizethedoubt
14 Oct 2013 14:57
Hey people, I am installing a starter for the first time, anyone know of a good video tutorial? Thanks
KZ 440 LTD 1982.
- StreetfighterKz
Re: How to install a starter
14 Oct 2013 15:03
It should be a pretty easy "remove and replace" job but I have no idea what bike you have so I can't give you specifics.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- prizethedoubt
- StreetfighterKz
14 Oct 2013 15:32
I've not worked on that particular bike but from what I've gathered looking at part diagrams: Your bike uses a chain driven starter clutch. You will have to either lean the bike to the right or drain the oil as you will need to remove the left engine cover to access the chain and sprocket that the starter motor drives. You should just be able to disconnect the cables from the battery, remove the chrome starter motor cover, and remove the two bolts holding the starter in after unbolting the large electrical cable. Then it's just a matter of wiggling out the old starter and reversing the order of the steps.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: prizethedoubt
