1980 KZ440 BRAKE LIGHT PROBLEM (SOLVED)
  • CheddarBob
  • CheddarBob's Avatar Topic Author
07 Oct 2013 10:20 - 09 Oct 2013 18:37
#609075
I HAVE A 1980 KZ440A LTD, THE BRAKE LIGHTS ALWAYS ON. THE RELAYS, WIRING AND BULB LOOK FINE. I HAVE KNOW IDEA WHAT TO DO. THE BRAKE WARNING LIGHT ON THE DASH BLINKS UNTIL I PRESS THE BRAKES THEN ITS SOLID. IF ANYONE HAS COME ACROSS THIS PROBLEM OR HAS ANY IDEA PLEASE LET ME KNOW.
THANKS!!!
Last edit: 09 Oct 2013 18:37 by CheddarBob. Reason: SOLVED PROBLEM
  • martin_csr
  • martin_csr's Avatar
Re: 1980 KZ440 BRAKE LIGHT PROBLEM
07 Oct 2013 13:46
#609113
The owner's manual should have info about the brake indicator light. The flashing indicator light means that there is a problem w the brake light circuit or the brake light itself is faulty.
Verify that the bulb is good. Turn the ignition switch to ON: the tail light should come on; apply the brake - the tail light should get brighter.
  • CheddarBob
09 Oct 2013 14:37
#609372
I FIGURED IT OUT THANKS ANYWAYS GUYS!
  • Cynjut
  • Cynjut's Avatar
09 Oct 2013 17:47
#609393
You gonna tell us what was so we can help out the next guy?
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
  • CheddarBob
09 Oct 2013 18:30
#609404
Honestly I'm a little in barest about it. Ok so I checked the bulb, wiring, everything, but when i checked the bulb i just looked at it. So yesterday I wondered if the tail light socket was all corroded, I took out the bulb and it felt apart. The inside of the 2057 bulb "blow up". I REPLACED THE BULB AND ALL WAS GOOD :)
Cynjut wrote: You gonna tell us what was so we can help out the next guy?
