Changing electric only, to kickstart. Am i kidding
  • jsnabbs
  • Topic Author
  • 1981 kawiKZ440
05 Oct 2013 17:18 #608871 by jsnabbs
As in the titel im trying to find out if this is possible, and if yes what and how is the best way to go about it.
Why would i want to do such a thing? well to cut down the electrics and battery, and there is something about kicking a bike over
Any info much appiciated and hello from a new member
TIME TO TRADE IN THE PEDALS FOR SOME POWER
05 Oct 2013 18:04 #608879 by martin_csr
Does your bike have a kick starter already?
  • jsnabbs
  • Topic Author
  • 1981 kawiKZ440
05 Oct 2013 22:02 #608889 by jsnabbs
No it has no kickstart, so i "guess" that means it would suggest an engine swap?
05 Oct 2013 22:09 #608892 by Nebr_Rex
KZ400 parts will work. Do a search here and over at KZ400.com .
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • jsnabbs
  • Topic Author
  • 1981 kawiKZ440
06 Oct 2013 02:27 #608906 by jsnabbs
so are you saying i should be abel to swap out/ buy/order part to convert it to kick start?
The kick start runs off the crankshaft i assume and you all so need a new housing.
what im trying to find out is, whats the easiest way of doing this, convert the motor or just swap it out?
This bike and motor will be torn down, wanted to have the topend off motor recond "hone bores,new rings, and valves and vale seats"
so it doesnt matter if its this motor or another that goes back into it
06 Oct 2013 09:46 #608917 by Old Man Rock
Replied by Old Man Rock on topic Changing electric only, to kickstart. Am i kidding
All this for a kick start 400cc displacement.... :S
Get another bike or at least engine for the bobber build (assumption).
If you feel the need to Bob it, get a 750 twin or Honda twin, any twin... I guess I'm just getting old to the point I don't get it (400/440 Bobbers). :laugh:
Hell, they're a dime a dozen here in the Phoenix area (sure it's the same in your areas)...
PPL saw-zaw the rear frame off, find out they don't have a clue fab or costs, get bored, still only a 400cc displacement etc... then sell cheap as a project bike.
Ah well, WTF do I know.... :blush:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
06 Oct 2013 09:57 #608918 by Nebr_Rex
jsnabbs wrote: so are you saying i should be abel to swap out/ buy/order part to convert it to kick start?
You need to do some more research.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
06 Oct 2013 12:02 #608925 by martin_csr
You should be able to get a definitive answer at the KZ400.com site. The crankcase is probably going to have to be split to install the kick starter stuff & I think you're going to need the right side clutch cover from a KZ400 - it has the kick starter hole.
The following user(s) said Thank You: jsnabbs
09 Oct 2013 16:27 #609380 by floivanus
+1 to what OMR said. I had a 76 750 twin and oh boy was that thing just arely enjoyable....
Why spend all the trouble on a 400 or 440? There's none kicking around that havent been cafe'd already. For what it would take to convert just find another one, put an ad on craigslist and for a couple hundred bucks you'll have a different bike or motor
Past; 78 kz1000, 83 kz550
Andrew
