Flashers, only right side
  • david-b
  • david-b's Avatar Topic Author
  • I am THAT guy
03 Oct 2013 11:53
#608646
Was wondering if anyone else has had the problem with their flashers. When I switch them on, just the right side will flash. When using the turn signals, both directions work fine. Traced the wires with no luck of finding any breaks/bad wires. Any ideas on where to look for this?
Realized this the other night when I had to pull off the road and turned them on.
Not a huge deal, but obviously looking to get everything in working order.
Thanks!
/Dave
2013 Chevy Sonic LT 1.4L Turbo
1982 Kawasaki KZ750-H3 LTD
1975 Monte Carlo 400sbc
  • MFolks
  • MFolks's Avatar
Re: Flashers, only right side
03 Oct 2013 13:33
#608652
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
BLACK with YELLOW stripe, the ground circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
I'd replace both of the silver can flasher relays, one controls the turn signals, the other, the 4 way flashers.
Check the bulbs & grounds too.
The following user(s) said Thank You: david-b
  • racer54
  • racer54's Avatar
03 Oct 2013 19:32
#608686
Here's another one....don't have turn signals on bike but when I turn on ignition, the left side indicator on instrument panel lights up. All the time...even when the switch is in the center location or off. Any ideas on this one?
  • elfmagic17
  • elfmagic17's Avatar
03 Oct 2013 21:54
#608696
racer54 wrote: Here's another one....don't have turn signals on bike but when I turn on ignition, the left side indicator on instrument panel lights up. All the time...even when the switch is in the center location or off. Any ideas on this one?
Most likely bad ground, broken filiment shorting to other filiment or corrosion in one or more socket.
Kenny Hicks
74 Honda CB550
  • elfmagic17
03 Oct 2013 21:56
#608698
david-b wrote: Was wondering if anyone else has had the problem with their flashers. When I switch them on, just the right side will flash. When using the turn signals, both directions work fine. Traced the wires with no luck of finding any breaks/bad wires. Any ideas on where to look for this?
Thanks!
Try swapping the two flashers and see if it works for hazzard that way.
Kenny Hicks
74 Honda CB550
  • Motor Head
  • Motor Head's Avatar
03 Oct 2013 22:22
#608701
Thanks!
I would suspect the handlebar switch. It makes the contact to both the R & L sides at once, power being sent through the flasher can.
With both sides working normally with the Turn Signal side of the switch, I'd look at the 4 way Hazard switch inside the left control. You can test it at the Harness connector for the left control.
  • Motor Head
03 Oct 2013 22:26
#608702
Since there are No Signals on the bike, there shouldn't be feed back from a bulb. Possibly the Indicator wire is connected wrong? Wrong wire/ bulb lit up but in the Turn signal indicator socket? You could just pull the wire or bulb out of that socket.
  • david-b
  • I am THAT guy
03 Oct 2013 22:32
#608704
I'll check out the switch and the flasher unit. Rained today so didn't have a chance but will check when I can. Thanks everyone.
/Dave
