Good small sized batteries?
  • danpcali
  • danpcali's Avatar Topic Author
  • I ride a 1980 kz650e
30 Sep 2013 03:33
#608307
I'm turning my 650 into a cafe. Want the area between rear wheel and engine
to be open (as much as possible). What kind a battery can help save me space
without breaking the bank? I'm assuming I should get 12v battery no matter what?
Re: Good small sized batteries?
30 Sep 2013 08:49
#608312
In order for folks to provide the best advice, please add your bike's year and model to your signature line. It matters. Especially on the KZ650 which went through several iterations of charging systems. Ed
The following user(s) said Thank You: danpcali
  • danpcali
30 Sep 2013 11:30
#608327
Sorry about that ed. I have a 1980 kz650e (limited). I will fill the info in my
profile too.
30 Sep 2013 12:08
#608331
You will need 12 volt. You may want to look into a Lithium battery. They are small and lightweight and can be mounted in any position since they don't contain acid. Try searching on Alienmotion, Ballistic, and Shorai; they are companies that market them for bikes; there are others as well. You may be able to use a capacitor instead of a battery if you plan to remove the electric starter. Others on this site may be able to provide guidance. Ed
  • bountyhunter
  • bountyhunter's Avatar
30 Sep 2013 17:23
#608375
danpcali wrote: I'm turning my 650 into a cafe. Want the area between rear wheel and engine
The Lithium type (Li Fe PO4) are the smallest and lightest and also the most expensive. Shorai sells them, I think they are in the $150 range.
  • Beaner242
  • Beaner242's Avatar
01 Oct 2013 09:20
#608446
try motydesign.com. several to choose from.
1982 KZ1000K LTD Chopper
