kz650 wont turn over
- NickMac
28 Sep 2013 00:52
I rebuilt my harness according to the barebones diagrams on this site and now the bike wont turn over. I have gone through and checked all connections and everything appears to be correct so Im at a loss. Im using the same Dyna S unit the bike had before I decided I was smart enough to fix a perfectly functional bike.
The biggest clue is when static timing, my timing light stays on regardless of crank position, but I have no idea how to interpret that. I had this same problem when timing 2/3 on initial installation and Dynatec replaced my Dyna S unit.
Here are some of my reading I have gotten:
12.5V at the battery
12.3V at the coils
4.2 Ohms primary coils (stock coils)
I did the continuity test per Dyna instructions and am getting nothing out of ordinary as far as plate to wire continuity.
12.3V at the coils
- Motor Head
Re: kz650 wont turn over
28 Sep 2013 10:33
There is some help on the Dyna website. See if it helps. You need a pdf file reader like Adobe Acrobat to open the files.
www.powercommander.com/downloads/Support...Manuals/DynaSTSG.pdf
www.powercommander.com/downloads/Support...anuals/DS2-1_2-2.pdf
