Points Plate and Hardware
  • handtius
  • handtius's Avatar Topic Author
Re: Points Plate and Hardware
26 Sep 2013 12:54
#607876
wow, that simple? no mods or anything, simple swap? do you know where i cab pick the electronic ignition?
Love me some bikes:
1976 Kawasaki KZ400D
1981 BMW R100CS
  • martin_csr
  • martin_csr's Avatar
26 Sep 2013 12:55 - 26 Sep 2013 12:56
#607878
madderkaw wrote: The process is remove the point plate and install the electronic ignition in it's place. That's it
What about the igniter, coil, & advancer?
Last edit: 26 Sep 2013 12:56 by martin_csr.
The following user(s) said Thank You: handtius
  • madderkaw
  • madderkaw's Avatar
26 Sep 2013 14:20
#607885
Like I said remove the plate and install the new ignition, no tuning, nothing. I got mine from Z1 Enterprises. I have one on my KZ900 and 650.
26 Sep 2013 16:15
#607903
madderkaw wrote: Like I said remove the plate and install the new ignition, no tuning, nothing. I got mine from Z1 Enterprises. I have one on my KZ900 and 650.
Really???
Here's the electronic ignition for the KZ650 that Z1 Enterprises offers. $425 and it includes all the parts needed as martin_csr pointed out. Don't misunderstand; I have no grudge against electronic ignition, but for that much money I could buy enough points and condensers to last more than 100,000 miles.
www.z1enterprises.com/ItemDetails.aspx?i...2f750&item=DYDDK2-2C
  • madderkaw
26 Sep 2013 16:24
#607905
This is the one I'm talking about $133.00, plug and play.
www.z1enterprises.com/ItemDetails.aspx?i...0%2f750&item=DYDS2-2
  • Cynjut
  • Cynjut's Avatar
26 Sep 2013 16:29
#607906
I installed a Dyna-S on my '77 KZ1000 and never looked back. My '82 already electronic ignition, so there's no reason to 'upgrade' that one, but installing the Dyna-S was one of the best upgrades I ever did. Simple, straightforward, easy-to-do (in front of the dorm in the parking lot), and worth every minute and dollar.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
26 Sep 2013 16:31
#607908
Dyna recommends using 3 ohm coils with that unit. Are you using the stock KZ650 4 ohm coils without any problems? Ed
  • handtius
26 Sep 2013 16:44 - 26 Sep 2013 16:45
#607910
madderkaw - "his is the one I'm talking about $133.00, plug and play.
www.z1enterprises.com/ItemDetails.aspx?i...0%2f750&item=DYDS2-2 "
Checking the site, this kit is made for KZ550 and up. Will there be a compatibility issue with the kz400?
Love me some bikes:
1981 BMW R100CS
Last edit: 26 Sep 2013 16:45 by handtius.
  • Cynjut
  • Cynjut's Avatar
26 Sep 2013 16:57
#607912
Dyna-S is for four cylinder bikes.
There was an article on here the other day about a guy that's selling a 2 cylinder electronic ignition. It works like the Dyna, but is for twins.
1977 KZ-1000 A1
  • madderkaw
27 Sep 2013 08:32
#607967
650ed
When I first installed it on my 650 I had stock coils, I changed them later, but not becuase it didn't run properly, one of the plug wires got damaged and they are permanently attached to stock coils. My 900 still has stock coils.
handtius
Call Z1, if there is anything for your bike they will know, and most likely have it in stock
The following user(s) said Thank You: 650ed, handtius
  • handtius
27 Sep 2013 15:23
#608013
For anyone interested, I just got off the phone with Z1 and the guy over there (Rob) said that they don't make them for the kz400, but he's heard of people modding the 750 to fit. Said I'd have to do some digging and it wouldn't be a straight swap out. He also mentioned Newtronics as an option, but didn't know if they made them for the 400 either. Going to just get the points plate from themotorcyclepartsoutlet.com
Thanks for all your help! You guys have all been great. Hopefully, when I start tinkering and screw something up, I can come here for some guidance on cleaning up my mess!
Love me some bikes:
1981 BMW R100CS
  • madderkaw
27 Sep 2013 16:21
#608019
Good luck. Is your KZ400 blue by any chance, I saw one on the west side highway the other day?
