Headlamps blowing at high speeds.
25 Sep 2013 23:22 #607801 by nickjcoco
Headlamps blowing at high speeds. was created by nickjcoco
I was riding down the highway at about 60mph tonight when my low beams went out. Flipped on the highs to get off the highway safely and those blew as well. It has happened twice before and always at highway speed. I'm no electrician so I have no idea where to start here. Fuses have been converted from the tube style to blades by my bike mechanic. Front end was rewired from a short caused by my high beam indicator light. 1978 KZ 750.
1978 Kawasaki KZ750 Twin
Cafe project/daily driver
  • Motor Head
25 Sep 2013 23:24 #607802 by Motor Head
Replied by Motor Head on topic Headlamps blowing at high speeds.
Probably overcharging. Check the voltage across your battery terminals at 4K RPM.
The following user(s) said Thank You: nickjcoco
25 Sep 2013 23:27 #607803 by nickjcoco
Replied by nickjcoco on topic Headlamps blowing at high speeds.
Thanks for the quick response. I'll unfortunately have to wait til the weeken to do that. No voltmeter.
  • testarossa
25 Sep 2013 23:37 #607804 by testarossa
Replied by testarossa on topic Headlamps blowing at high speeds.
+1 on the overcharging. When my voltage regulator went out it could get up to 17 volts at speed Motorhead is right, the charging system needs to be checked at 4000 rpm to see full voltage.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
25 Sep 2013 23:37 #607805 by RonKZ650
Replied by RonKZ650 on topic Headlamps blowing at high speeds.
If the charging system checks out, it may be crap headlights. I changed over from the factory sealed beam over to automotive type way back in about 1983 and it's worked great, but all bulbs are not created equal. Lots of garbage out there, the old Walmart type stuff. Used to be you could buy motorcycle H4 bulbs that would last, where automotive was junk, but now chances are all are junk.
25 Sep 2013 23:39 #607806 by nickjcoco
I'm going with all are junk. The bulbs I've been using are Automotive H3s.
26 Sep 2013 04:20 #607831 by Lt.Dan
Replied by Lt.Dan on topic Headlamps blowing at high speeds.
I have seen this condition the serious overvolting when the battery is been sitting a long time and someone goes out on the freeway and gets up to speed. Seen the bulbs Hdlt-Tailight and coils fried on a motorcycle that had been sitting and jump started and was driven at freeway speeds. I think that thing was putting out over 16 volts to the battery. The Vr gets tricked by the low battery voltage and lets the alternator go max...
  • Proxy
  • 80% Human 20% Nuts/Bolts
27 Sep 2013 18:25 #608035 by Proxy
Replied by Proxy on topic Headlamps blowing at high speeds.
Another thing is if you changed the headlight mount you have to isolate the headlamp with some sort of dampner/rubber because the vibrations are killer. Especially at higher speeds. A lot of vibrations come from the engine and the road and take a great toll on un-dampened filaments. This is why the manufacturers put the rubber thingies in there. I have seen a lot of customisers just sock a shell down and start going through headlights. So if the juice is running ok look at your headlight mounting. Luck!
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
27 Sep 2013 18:34 #608037 by nickjcoco
Thanks, Proxy. I do have the stock bucket on there with rubber on the mounts. I do notice some vibration but feel it may be an overcharging issue as Motor Head suggested. I'm going to get a voltmeter from a friend this weekend to test out the voltage. I have had a handful of electrical issues with this bike. Mostly stemmed from my friend that I bought it off of. Amateur rewiring and a relocated ignition that has been the bane of my existence. 35 year old parts are probably also at play here. This forum has been a godsend. Thanks to everyone.
27 Sep 2013 18:47 #608039 by turboking
Replied by turboking on topic Headlamps blowing at high speeds.
automotive bulbs never did work well due to the vibration of the bike,potholes ,etc...... but it does sound like you have an overcharging problem....... :huh:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
27 Sep 2013 18:52 #608042 by nickjcoco
Now the question is, when/if I pinpoint it to an overcharging issue...is this a rectifier problem? As in am I going to need to replace that? Or is there some tweaking I can do to remedy the issue?
27 Sep 2013 21:17 #608051 by 650ed
Replied by 650ed on topic Headlamps blowing at high speeds.
The rectifier converts AC power from the dynamo into DC power to charge the battery. If your bike has a separate regulator and a separate rectifier, overcharging is more likely to be a regulator problem. If your bike has a combined regulator/rectifier that unit may be the problem. You can use the instructions in the Kawasaki Service Manual to test the charging system components. That way you can identify exactly which part(s) is failing. Usually, parts of the charging system that fail should just be replaced rather than trying to repair them. Ed
