easiest way to convert to kick only?
  • Plug.ugly
  • Plug.ugly's Avatar Topic Author
21 Sep 2013 18:28
#607279
I have a 79 Kz400 that seems to come factory without kick at all. I'd like to convert it to kick start only, but I'm not really sure how to go about this. Any and all advice will help, thanks.
  • kzz1king
  • kzz1king's Avatar
Re: easiest way to convert to kick only?
21 Sep 2013 22:19
#607306
I won't say impossible but if that motor never came with kick it will be tough. Did other years of this motor have a kicker?
Wayne
Home built KZ1000 turbo setup
  • jeffasaki
  • jeffasaki's Avatar
21 Sep 2013 22:48
#607310
put a worn out starter solenoid on that only works if you tap on it
then just wire it up so its around where the back brake peddle is
then hold the starter button down and kick away at the old worn out solenoid
until it starts. you will feel way cooler then you do now
and get way more pussy
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
21 Sep 2013 23:30
#607314
kzz1king wrote: I won't say impossible but if that motor never came with kick it will be tough. Did other years of this motor have a kicker?
Wayne
Actually, according to Kawasaki.com every year and model KZ400 came with a kickstarter as standard equipment. Maybe he has a different engine in the bike (KZ440?) and doesn't know it. ;) Ed
  • Nebr_Rex
  • Nebr_Rex's Avatar
22 Sep 2013 00:27
#607317
Wayne
Yep, all 400s came with kick start. Some were even kick start only. Take a look
at the front of the cylinder block. On the bottom, towards the center. It will tell
you the original cc. I bet it's a 440, none came with a kick start. You can convert
to kick start, but you have to split the cases. Use either a true '79 - "80 KZ400
kick start mechanism or use the earlier KZ400s kick start mechanism with
both first gears. Shafts are the same spline, the teeth are different and the gears
are a different width. You will also need the "79-"80 clutch cover. There is one bolt
that is in a different place from the earlier cover and the 440 doe not have the hole
machined for the seal.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Plug.ugly
22 Sep 2013 13:05
#607361
Wow, ok. I'll have to look into that. Thanks. Definitely looking forward to all that pussy though, I mean why else would I want a kickstart?
