weak spark
  • mopguy
  • mopguy's Avatar Topic Author
Re: weak spark
07 Oct 2013 10:59
#609082
MFolks,thanks a lot.
  • loudhvx
  • loudhvx's Avatar
Re: weak spark
07 Oct 2013 14:40
#609131
KZ igniters use a ground wire for ground, not necessarily the backing plate.
  • mopguy
Re: weak spark
12 Oct 2013 19:18
#609789
Thank you all, after a good cleaning I am now getting battery voltage at the ignition coils.
  • MFolks
  • MFolks's Avatar
Re: weak spark
12 Oct 2013 21:58
#609809
It really does not take much corrosion to lower voltage and current sources for the ignition system. I'd suggest cleaning the many and various electrical connectors & switches at least every other year(especially if you live in a salt air environment, like a beach city).
  • mopguy
Re: weak spark
31 Oct 2013 11:23 - 31 Oct 2013 13:12
#611723
I have not been to the bike in a couple of weeks, fixed voltage to the coils, and now she wont turn over. I cleaned and painted battery holder box, reattached ic igniter along with all the other components, and now it wont start. Solenoids tested 3.5 ohms resistance at plug. Solenoid is not getting power at the plug, when clutch is engaged and starter button is pushed. I ordered a factory repair manual finally, however any ideas on where to look for fault will be appreciated. Forgot to mention, I have power at the ignition switch and starter button.
Disregard this post as I figured out where the problem was using a Kawasaki KZ750 1980-1983 clymer manual. I used the blue print that I could read and the fault was at the starter disconnect switch. MFolks, thanks again.
Last edit: 31 Oct 2013 13:12 by mopguy. Reason: found problem
  • Troyn
  • Troyn's Avatar
Re: weak spark
01 Mar 2014 16:24
#623774
Patton wrote: Where battery passes the load-test, coils are supposed to receive same voltage produced by the battery.
Would determine and resolve voltage loss between battery and coils.
Good Fortune! :)
Great diagram! On the above, for my bike, where does the integrated voltmeter (on the tach gauge) get its reading? I'm seeing 10.75 volts at the coils, at the ignition coil connector near the rear brake and also on the integrated voltmeter.
I've gone through about every connector with deoxit so far but haven't done the ignition switch or run/kill switch yet.
Also the pickup coil wire readings at the igniter were all infinite so looks like my igniter is bad too.
Thanks!
1983 kz750 ltd shaft, 4-cyl, stock everything :)
Re: weak spark
01 Mar 2014 19:33
#623806
Here's a link to download the wiring diagram found in KZr's FILEBASE:
www.kzrider.com/filebase/search/finish/1-general/265-kz750f1
If not already done, would assure that the black/yellow wire is providing a good ground from the igniter.
Good Fortune! :)
  • Troyn
  • Troyn's Avatar
Re: weak spark
01 Mar 2014 19:50
#623812
Thank you! I think I recall the black/yellow grounded at a metal strip right under the seat, I'll check tomorrow.
