Electronic Ignition Conversion
- themavrik
17 Sep 2013 00:14
Looking for some guidance in converting to electronic ignition on my 1982 KZ1000 K2-LTD.
Any suggestions, DIY guides, previous forums (I did search a bit) related to my specific model they would be appreciated. I'm fairly mechanically inclined and have a decent amount of experience in figuring things out as I go but when it comes to electronics I'm less familiar. I'm hoping its a matter of remove 'this part' replace 'that part' and a few wire connections, especially helpful would be a list of components needed.
Thanks!
Thanks!
- Nebr_Rex
Re: Electronic Ignition Conversion
17 Sep 2013 00:19
Your not serious are you?
Kawasaki has used electronic ignitions on KZ1000 since '79.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
The following user(s) said Thank You: themavrik
- themavrik
17 Sep 2013 10:13 - 17 Sep 2013 10:15
Howdy. I believe your bike has a mechanical timing advancer - it's the only serviceable part --> you should clean & lubricate it. The factory manual has the specifics. I don't know the best lubricant to use - white lithium & dielectric grease didn't seem to work very good as they evaporated or something -->> my advancer became dried out. I used high-temp wheel bearing grease last spring - I haven't had the pulsing coil cover off since to check it, so only time will tell how that worked.
Something else you can do is redo the spark plug wire connections. At the coils unscrew the ribbed compression boots. If the wires don't come off, untwist them from the coils.
The Kawasaki electronic ignition is good, but the stock coils are supposedly the weak link (some experienced Kaw mechanics say they weren't that great when new). There are aftermarket coils available - Accel & Dyna are a couple.
Last edit: 17 Sep 2013 10:15 by martin_csr.
- sbc1320
17 Sep 2013 12:04
Yeap my 80 is factory electronic with Accel coils and wires.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
