wire problem has e stumped
  • Kruulish
  • Kruulish's Avatar Topic Author
13 Sep 2013 13:18
#606297
not sure when this happened but my tail light wont come on unless i switch the key to acc..i dont know where to start on this cause the brake lights work fine.
  • Kruulish
Re: wire problem has e stumped
13 Sep 2013 13:28
#606298
just realized i posted this in the wrong place...oh what a morning
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
13 Sep 2013 13:40
#606299
rem that the bulb has two elements.....brake.....running light. One can go bad and the other will work.
Could be as simple as installing a new bulb, this happened to me once and it was a bad bulb.
Try a new bulb first.
13 Sep 2013 14:39
#606309
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do. Here's how:
Attachment addsig.jpg not found
From another thread, am guessing '77 KZ650.
Here are links to wiring diagrams in KZr's FILEBASE for the 1977 KZ650.
www.kzrider.com/filebase/cat_view/95-197...5-kawasaki-kz-650-c1
www.kzrider.com/filebase/cat_view/95-197...6-kawasaki-kz-650-b1
Good Fortune! :)
The following user(s) said Thank You: Kruulish
  • Kruulish
15 Sep 2013 04:20
#606489
its not the bulb cause the tail light comes on on acc. its a 77 kz650. also forgot to mention the gauge cluster lights wont come on.
  • Motor Head
  • Motor Head's Avatar
15 Sep 2013 10:20
#606506
Replace the Tail light Fuse in the Fuse Panel, and then see if it works.
The Ignition Switch has two different ways of powering the circuit. When in the normal ON position it needs this Fuse to be good. But in the Park position it goes through the Main Fuse.
Here is a wiring Diagram for you. Not sure of your Model, but this should be close.
www.kzrider.com/filebase/doc_download/289-z650c1
