Repalcing an ignition in 1980 ltd 650
  • Kieran_z750
  • Kieran_z750's Avatar Topic Author
05 Sep 2013 16:34
#605050
A friend of mine lost his keys, ordered a new ignition online, but can't get the old one out. He removed all the headlights, turn signals, etc and exposed the ignition. It won't come out! After a while of angry pulling, he pulled the actual wires from the back of the face of the ignition. Now just the metal cap and casing remain in the bike. He hooked the new one into the bike, but it won't start still. The old ignition had 7 wires (a brown one is 7th and was outside the white rectangular housing) and the new one only has 6 (no external brown wire).
1 - how to get original ignition the rest of the way out?
2- do I need to get that brown wore hooked up for the new ignition to work?
  • martin_csr
  • martin_csr's Avatar
Re: Repalcing an ignition in 1980 ltd 650
05 Sep 2013 17:04
#605055
Did he try removing it from the underside? The diagrams at Kawasaki.com or Partzilla might be helpful (ignition switch & meters). His bike is different, but on my 81 650 I have to remove 2 allen bolts on the underside.
  • MFolks
  • MFolks's Avatar
05 Sep 2013 17:44
#605070
That's the way it is on my 1982 GPz 1100 B2. Lower the headlight & the Allen head bolts are right there.
  • martin_csr
05 Sep 2013 19:38
#605096
His seems to be different. I can't tell from the diagram if there are any bolts that secure the switch.
There are a couple of tabs at the base of the ignition switch, and at the top there appears to be a retaining ring that looks like it should be unscrewed.
The following user(s) said Thank You: Kieran_z750
  • Kieran_z750
06 Sep 2013 00:34
#605134
so here are a few photos i took this afternoon. the one called moto back 2 shows the ignition from the back with the wiring removed. there is just a metal casing still there that i can't get out. on the photo that says ignition top, shows the ignition top still in there. i tried to start it this afternoon and it seemed like it was close to starting, but now the electrical systems don't even go on when i turn the key in the new ignition. weird. any ideas?
  • Kieran_z750
06 Sep 2013 00:37
#605135
yeah we've pretty much removed every bolt/screw in sight. no go. i'm looking at the wiring guides you suggested from the kawa site now. thanks for the suggestion.
06 Sep 2013 00:43
#605138
Did you unscrew the plastic ring on top around the keyhole and lift the idiot light cover off? Ed
  • Kieran_z750
06 Sep 2013 12:31
#605195
I didn't think the black plastic ring came off. I've tried with my hand, wrenches, and pliers, but it hasn't budged. Is that supposed to come off? What is this idiot light you speak of?
06 Sep 2013 14:20 - 06 Sep 2013 14:22
#605206
Kieran_z750 wrote: I didn't think the black plastic ring came off. I've tried with my hand, wrenches, and pliers, but it hasn't budged. Is that supposed to come off? What is this idiot light you speak of?
Yes, it should just unscrew using your fingers, and then the cover just lifts off. Here's mine. Ed
Attachment IMG_7485.JPG not found
Attachment IMG_7488.JPG not found
Attachment IMG_7489.JPG not found
Attachment IMG_7490.JPG not found
Last edit: 06 Sep 2013 14:22 by 650ed.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
15 Sep 2013 22:35
#606614
Should have given me the key code # and I could have cut you a key.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
