No Power
  • Hoog
  • Hoog's Avatar Topic Author
No Power
31 Aug 2013 17:21
#604168
Hello all, I'm hoping for a little insight on a problem I'm having. I can't seem to find it on my own. I have an 82 GPZ750. When I turn the key on I get a neutral light only. No power to lights, starter, etc. All fuses are good, everything looks ok, but nothing... thanks in advance
  • MFolks
  • MFolks's Avatar
Re: No Power
31 Aug 2013 17:48
#604176
Replace all of the fuses, as the old glass tubed ones will look good, but have failed internally. Also, check the electrical connections inside the headlight housing for corrosion, or disconnected wires. The right handlebar switch pod, contains the run/stop and start switches. The older bikes are seeing solder joint failures, so inspect those too. If you find bad soldered joints, just ask, as I've got a repair procedure for this.
