Ignition Switch Problem - Reinstalled Incorrectly
- AndrewAcosta
27 Aug 2013 21:33
I lost my key so I removed the ignition switch and took it to a locksmith to have a new key made. I must have reinstalled the switch incorrectly because now with the handle bars unlocked I cannot turn the key to the on position. The shop manual has no information on removal and correct installation. Can anyone help? The key only tuns to "lock" or "park". When it was first reinstalled it was in the "off" position and I was able to start the bike, but the handle bars were locked. When I moved the key to the "lock" position the handle bars unlocked, but now the bike will not start and I cannot get the key back into the "on" position.
- MFolks
Re: Ignition Switch Problem - Reinstalled Incorrectly
27 Aug 2013 22:48
Can you lower the headlight housing, and access the two Allen head screws holding the ignition switch? If so, take them out & try to get the fork lock to disengage & then re-install the switch correctly.
- AndrewAcosta
28 Aug 2013 09:58
Thank you. I'll try that.
