Starter Motor
  • Tigerbob800
  • Tigerbob800's Avatar Topic Author
Starter Motor
27 Aug 2013 09:09
#603308
Hi All
New to this forum. My name is Mark I have just got a 1981 KZ 750 E got it as non runner electrics melted. I have stripped them back and have got the engine running but I don't have ignition lights apart from main beam any advice would be grateful. Also does the starter stay engaged when the engine is running?
Hope someone can help thanks in advance Mark
  • Motor Head
  • Motor Head's Avatar
Re: Starter Motor
27 Aug 2013 10:07
#603314
Welcome to KZR! Got any pictures of your bike?
If you go here, www.kzrider.com/filebase/doc_download/294-z750e2 there is a wiring diagram for your bike.
As for the starter, No it should not stay engaged once you let go of the Start Button.
Of course check all fuses, with either a test light or better yet a Volt Meter. Looking at those glass fuses will fool you, they can look fine but be defective.
  • Tigerbob800
Re: Starter Motor
27 Aug 2013 15:00
#603344
Thanks very much the diagram will a lot seems like its the wires for the lights that have melted I will splice in new wires hopefully this will fix it
Not sure I've done this right if I have there should be a picture of my bike
