Shorai batteries
  • dadgonebroke
  • dadgonebroke's Avatar Topic Author
Shorai batteries
26 Aug 2013 20:43
#603220
I got tired of battery acid dripping on the exhaust,, etc., so I purchased 2 Lithium Ion batteries for my (2) Z1's and 1 for my '76 900LTD. The one for the LTD lasted a couple of weeks before it wouldn't even turn the starter over. I measured voltage @ 13.5 volts and over 14 after I kick started it. That battery was replaced free of charge minus shipping a month or 2 ago.
Well- today, I went to start the '75 Z1 and "deja vu!" Thinking maybe the bike maybe had a short- I replaced the Shorai with the one in the '73. Same no start! Time to initiate another return to Shorai!
Any of you guys had any issues with these batteries?
  • bountyhunter
  • bountyhunter's Avatar
Re: Shorai batteries
27 Aug 2013 03:48
#603291
I have not yet tried one although I was tempted because of the light weight. I believe they are Li Fe PO4 chemistry types (lithium iron phosphate) which is what the electric car developers used here for many years. The thing I know about Li chemistries is they are typically sensitive to being overcharged. The charging system of a bike is not precision.... it's typically about 14V +/-0.5V. I am not sure how an Li battery is going to like that?
I have been waiting to hear more reports on them before buying myself. Some reports have been good, some not.
  • testarossa
  • testarossa's Avatar
27 Aug 2013 07:09
#603296
Might the acid dripping on your exhaust from the previous battery be a clue. Typically dripping battery's are overheated batteries. Overheated from overcharging in my experience. Sounds like you may need to test your charging system. I had my regulator go bad and the bike was charging at almost 17VDC! That was enough to cook battery's and light bulbs.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • steell
  • steell's Avatar
27 Aug 2013 19:03
#603379
I have an Alien Motion Lithium battery in my 750 twin, going on two years without a problem, started right up with no charging after the winter.
So, you have three bikes, and three bad Shorai batteries? Wow! Sure am glad I bought a cheap one rather than the Shorai. :)
  • dadgonebroke
27 Aug 2013 19:19 - 27 Aug 2013 19:21
#603380
I got my return authorization today and they said because I purchased it a year ago, the price of a new one is of 75% off RETAIL price for a new one. I had purchased the battery last August and it sat unopened until this June, so I'm hoping they relent and just send me a new one gratis!
Last edit: 27 Aug 2013 19:21 by dadgonebroke. Reason: spelling
  • bountyhunter
28 Aug 2013 02:54
#603452
dadgonebroke wrote: I got my return authorization today and they said because I purchased it a year ago, the price of a new one is of 75% off RETAIL price for a new one. I had purchased the battery last August and it sat unopened until this June,
Did you charge it before use? Sitting close to a year without being on a tender is not good for a battery.
  • dadgonebroke
18 Sep 2013 13:17
#606931
Thanks to Shorai for a no charge replacement that I received yesterday! One thing I did also, was to replace the regulator and rectifier on the '73 and '75 with new style regulators from Z1parts.
I must say that most of these regulator/rectifier setups on these Kawasaki's, apparently are guilty of overcharging situations but I wasn't aware how sensitive these Lithium batteries are to the overcharging. Now, any possibility of overcharging is hopefully gone and I can finally see how good these Shorai batteries really are!
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
19 Sep 2013 12:47
#607052
keep us posted .
i have been wondering about them.
  • testarossa
19 Sep 2013 13:38
#607064
531blackbanshee wrote: keep us posted .
I happened upon a display of Shorai batteries when at Batteries Plus looking for a coin battery for an older laptop. The Shorai batteries are impossibly small and lightweight. I would like to try one out the next time I have occasion to replace the battery on my bike. However that AGM battery is soldiering on without complaint still to this day.
2004 ZX-10R
Angola, IN
  • StreetfighterKz
  • StreetfighterKz's Avatar
19 Sep 2013 14:14
#607071
I put a Shorai in my Ducati Monster and it worked really well. I had to make a bracket to hold the battery in because of the large size difference from the stock battery.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • Cynjut
  • Cynjut's Avatar
19 Sep 2013 16:13
#607087
testarossa wrote: Might the acid dripping on your exhaust from the previous battery be a clue. Typically dripping battery's are overheated batteries. Overheated from overcharging in my experience. Sounds like you may need to test your charging system. I had my regulator go bad and the bike was charging at almost 17VDC! That was enough to cook battery's and light bulbs.
A lot of people seemed to blow past this. It's important - battery acid coming out of the battery is a sign of over-charging. If you are seeing this consistently, you really need to get your rectifier and regulator double checked before you replace the battery again, even if you use a regular battery and don't switch to the LiFePO4 class of batteries.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
  • bountyhunter
19 Sep 2013 16:44
#607094
+1 Overcharging kills batteries. Especially the Li types.
