Headlight / Switch pod
  • Schmeck
  • Schmeck's Avatar Topic Author
24 Aug 2013 18:41
#602912
Hello, So my 1979 kz750 twin headlight stopped coming on awhile back and after sorting out other issues I can finally work on this one. My headlight comes on when hooked up to my truck, But not when hooked up to the bike. Fuses are good, 3 prong plug to headlight was just replaced, and I have alittle bit of voltage in my switch pod.I set the meter to 20v and I get 0.652. From what I can see the switch box is faulty. All of the wires read the same voltage .Considering everything else works except the headlight, I want to say its the switch pod. Can anyone back this theory up? I will replace the switch if that is the issue. -Tyler
Btw- front turn signals were removed if that has anything to do with the circuit.
1979 kz750 twin -Soon to be roadworthy
1988 El250 engine in custom hard tail frame - collecting dust
  • bountyhunter
  • bountyhunter's Avatar
Re: Headlight / Switch pod
25 Aug 2013 03:07 - 25 Aug 2013 03:08
#602952
Wiring diagram for the 79 750 twin. Could be a switch or a harness connector or a fuse connection or just about any connection point.
Last edit: 25 Aug 2013 03:08 by bountyhunter.
The following user(s) said Thank You: Schmeck
  • Schmeck
25 Aug 2013 15:59
#603013
Thanks alot for the diagram . The one I have was printed so its hard to read . Headlight is on. yes B)
