Weak headlight
- ThatGPzGuy
Weak headlight
22 Aug 2013 08:19
Rode the bike in to work this morning. First day in two weeks without rain!
I have been noticing how weak my headlight is. It is yellow and does not illuminate very much. It is almost like not having a light on at all. However the high beam is nice and bright. Is this normal?
If it needs replacement is there a decent alternative to stock for the square headlights? This is on the 82 GPz750.
TIA,
Jim
TIA,
Jim
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Re: Weak headlight
22 Aug 2013 08:53 - 22 Aug 2013 08:54
You shouldn't need to replace the headlight. The stock headlight will have a replaceable bulb; I'm pretty sure it is the "H4" type, so they are readily available. The stock 55 / 60 watt bulb should be plenty bright even on low beam, so if you replace the bulb and low beam is still dim you need to check the wiring. Ed
Attachment 00001_2013-08-22.jpg not found
Last edit: 22 Aug 2013 08:54 by 650ed.
- koolaid_kid
Re: Weak headlight
22 Aug 2013 12:49
The rectangular headlight on my 83 has an H4 bulb, pretty sure yours does also. When I replace mine I will use something like the Sylvania 9003/HB2/H4 SU SilverStar Ultra Halogen Headlight Bulb.
However, a yellow glow usually indicates low voltage, so I suggest checking the voltage first.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- MFolks
Re: Weak headlight
22 Aug 2013 13:08
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
- Kidkawie
- I bleed premix
Re: Weak headlight
22 Aug 2013 13:17
Sounds like a bad/corroded connection somewhere. Have had that on all my Kaw street bikes at some point or another. Break out the WD40 and start unplugging and spraying.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- koolaid_kid
Re: Weak headlight
22 Aug 2013 14:09I agree mostly. Rather that using Water Displacement formula 40 (WD40) I recommend Deoxit D5, which is specifically designed for the task.Kidkawie wrote: Sounds like a bad/corroded connection somewhere. Have had that on all my Kaw street bikes at some point or another. Break out the WD40 and start unplugging and spraying.
1983 GPz 750
- ThatGPzGuy
Re: Weak headlight
23 Aug 2013 08:12
I guess I spoke too soon. Rained like h*ll on the way home.
Thanks for the help. I'll pull the bulb and check the connections.
Jim
Jim
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- Motor Head
Re: Weak headlight
23 Aug 2013 09:15
"File Base" has your wiring diagram for you.
www.kzrider.com/filebase/doc_download/312-z750r1
- ThatGPzGuy
Re: Weak headlight
25 Aug 2013 09:27
Thanks Motor Head. That diagram was a big help. I also figured out why my running lights were not working.
Jim
Jim
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- ThatGPzGuy
Re: Weak headlight
27 Aug 2013 20:15
Well that worked out pretty well. I cleaned the connections and got the bulb a little brighter. Since I already had it out I went ahead and bought a new bulb at the local AP store. Rode the bike into work this morning and I noticed a great improvement. In fact I didn't even bother changing my face shield from black to clear. Much better and safer too...
Thanks,
Jim
Thanks,
Jim
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- MFolks
Re: Weak headlight
27 Aug 2013 21:13
H4 bulbs get dimmer with time, so every so often, do a walk around, with the lights on & replace all other bulbs(running, brake,& turn signals),too.
