right turn signal only flashes when bars are turnd
- delta 224
18 Aug 2013 10:49
I have a Kz440 LTDA and the right signal flashers only turn when the bars are at certain positions. It seems like some sort of short but I don't know which wires to start looking at.
- MFolks
Re: right turn signal only flashes when bars are turnd
18 Aug 2013 13:51
Open up the headlight housing, and look for possible broken or corroded wires going to the right turn signal assembly. Here's some color codes:
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
HEADLIGHT
- uncle nick
19 Aug 2013 16:04
I'd also check the cable going from the headlight to the switch where it curves round the headstock. I've had one break inside there before yet the outer plastic looked fine, a bugger to find! :evil:
1981 KZ650 CSR
