Help! Brake light and Neutral light stopped workin
  • jhayward
  • jhayward's Avatar Topic Author
17 Aug 2013 18:06
#601881
Good afternoon. 1983 kz750-N1 Spectre. Turned it into a bobber. Just about done with the bike. I just put an aftermarket LED tail/brake light on. It worked just fine. took it for a ride. pulled back into the garage then noticed the headlight wasn't on anymore. turned it off and lit up a smoke. turned ignition back on and the headlight came on. Put the bike in neutral and noticed the neutral light isnt on. tail light and headlight were on but the brake light wouldnt switch on.
anyone have any ideas? where should i start? Fuses are good. bulbs are good.
