Condenser Failure?
  • CDNTX650
  • CDNTX650's Avatar Topic Author
Condenser Failure?
11 Aug 2013 11:41
#600830
Bike has been running great all summer, Points were pitted so I cleaned them up to finish the riding season and used my new condenser about 3 months ago. Well last night I barely made it home. Open up the points cover and it looks like a fireworks show.
Installed the new points that finally came in and still sparking on the contact faces like mad. Condenser appears to be bad. Do they fail because of pitted faces or did I just get a bad one in the set?
Re: Condenser Failure?
11 Aug 2013 11:44
#600831
You should replace the condenser every time you replace the points. That's normal tune-up procedure. Ed
  • Z1Driver
  • Z1Driver's Avatar
  • love the smell of triple smoke
11 Aug 2013 16:48
#600870
My recommendation would check to make sure your condenser leads are connected to the points properly. Sparking points are an indication of a bad condenser or condenser leads touching something they should not be. Last time I had this issue, one of the condenser leads was placed on the wrong side of a fiber washer on the points. HTH, Z1Driver
Blue 1975 Z1B
Red 2009 Concours 14
  • Motor Head
  • Motor Head's Avatar
11 Aug 2013 20:17
#600899
If you have the money to upgrade to an electronic system i would do that. Points do work, and can be fixed on the side of the road. But the electronic systems that Kawi made in the 80's is very reliable. You should be able to retrofit it to your model very reasonable. Then set it and just lube the advancer during regular maintenance.
  • CDNTX650
12 Aug 2013 00:16
#600949
Well, I want a dyna or boyer, but right now after a 10,000 km bike trip for our honeymoon funds are tight. Figured 30 bucks for 2 condensers so I have a set as a spare aint to shabby.
Condenser leads were good. Bike ran great for about 3 months. cylinder 2-3 was the one sparking horribly.
  • koolaid_kid
  • koolaid_kid's Avatar
12 Aug 2013 03:56
#600970
What country do you live in? I ask because it seeems that Z1Enterprises has the whole set for around $30 if I remember correctly.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • CDNTX650
12 Aug 2013 08:10
#600977
Canada. Bought em from parts n more. Figured a spare set is a good investment till I ditch the points for good.
