77 kz650B1 diagram check
- NickMac
06 Aug 2013 18:28
I am rebuilding my harness using the barebones diagrams on this site and have included the wired george coil mod. I drew up a diagram and i want to make sure it looks okay too you guys before I start putting it together.
thanks!
thanks!
Attachment SCAN0001.JPG not found
- btchalice
Re: 77 kz650B1 diagram check
08 Aug 2013 02:01
not sure how the dyna wires up but from what i can see there you have a few issues with it , ill see if i can find a diagram that will work
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- btchalice
08 Aug 2013 02:38
i modified someones diagram from another thread one with and one without the wg coil mod
what you had was missing a power source for the relay and the starter. plus the wgmod for the coils uses a relay to direct link the coil to the battery for hottest spark.
if i'm wrong i'm sure someone will correct me
Attachment barebones.gif not found
Attachment barebonesplusswgmod.gif not found
- NickMac
08 Aug 2013 15:32 - 08 Aug 2013 15:41
I appreciate your response and that clarified the relay greatly. Could you explain the purpose of have two sources of power for the starter solenoid? I haven't seen this on other diagrams. I see one directly from the battery and another from the relay. Am i missing something?
btchalice wrote: i modified someones diagram from another thread one with and one without the wg coil mod
Last edit: 08 Aug 2013 15:41 by NickMac.
- btchalice
09 Aug 2013 01:35 - 09 Aug 2013 01:36
the main wire to the solenoid is main battery power that connects to the starter when active. the other is to activate the magnet inside the solenoid to turn it on
i just added the wire from the relay to the solenoid to show a good source of power for the wg mod
Last edit: 09 Aug 2013 01:36 by btchalice.
- NickMac
- loudhvx
09 Aug 2013 18:45 - 09 Aug 2013 19:25
None of those diagrams will work for a 1977 KZ650 as drawn except the C1 for Johnny C. They all need various changes, and the Johnny C version uses a different ignition switch and no relay.
Let me see if I can dig one up, or just draw one from scratch.
Some relays have two 87 contacts. Either one can be used.
Some relays have an 87 and 87a contact. Don't use 87a.
I posted it on the Mattylight thread, and linked it here:
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 09 Aug 2013 19:25 by loudhvx.
- btchalice
10 Aug 2013 02:55
like i said if i have it wrong somebody would correct me you can trust loudhvx he knows his stuff
