80 kz750ltd h1
  • kzrider616
  • kzrider616's Avatar Topic Author
80 kz750ltd h1
06 Aug 2013 14:59
#600104
:angry: can ne one tell me where the two wires (one yell/red the other black), running out of the starter relay go to? Again 80 z750 ltd h1 four cylinder. I havethe diagram only im still having trouble and im almost doooone. Cant wait to fire her up
Re: 80 kz750ltd h1
06 Aug 2013 15:19
#600105
kzrider616 wrote: :angry: can ne one tell me where the two wires (one yell/red the other black), running out of the starter relay go to? Again 80 z750 ltd h1 four cylinder. I havethe diagram only im still having trouble and im almost doooone. Cant wait to fire her up
Hello, kzrider616, and WELCOME to the forum! :cheer:
The excellent wiring diagram in KZr's FILEBASE shows connections of the wires in question.
Here's a link to the diagram:
Click > www.kzrider.com/filebase/doc_download/293-kz750h1
Or may access the FILEBASE, then navigate 1st to the year, 2nd to the model, and 3rd to the desired topic.
Attachment filebasekzr.jpg not found
Here's an excerpt:
Good Fortune! :)
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: 80 kz750ltd h1
06 Aug 2013 15:30
#600106
According to the wiring diagram, the black lead goes to the starter lock out switch, either at the clutch lever or the side stand - I am not sure which one it is on that model. But it is one or the other.
There is a red/yellow lead but not a solid yellow lead? The red/yellow lead connects to the black/yellow ground cirucit.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • kzrider616
Re: 80 kz750ltd h1
06 Aug 2013 18:46
#600129
Ok so i got that figured out now i need to know if i can usemy78 gl1000 coils (tec101-12v), on the kz if i get rid of the resistor?
Re: 80 kz750ltd h1
06 Aug 2013 20:27
#600147
kzrider616 wrote: Ok so i got that figured out now i need to know if i can usemy78 gl1000 coils (tec101-12v), on the kz if i get rid of the resistor?
Ant dual-tower ignition coil having primary resistance per FSM specs should suffice.
Good Fortune! :)
