electrical system upgrade 81 650csr
- jbalet666
Re: electrical system upgrade 81 650csr
06 Aug 2013 19:15
yeah i really havent messed with it that much but that saves me a whole lot of time
81 650csr
AoA
old soul young blood
AoA
- MFolks
06 Aug 2013 19:33
Maybe something like this would work:
www.whitehorsegear.com/bikemaster-12-volt-mounted-power-adapter
07 Aug 2013 10:05 - 08 Aug 2013 10:28
The accessory fuse box is behind the left side cover rearward mount. One 10A fuse has a black/white lead which terminates nearby. The other 10A fuse has a blue/white lead which terminates at the headlight bucket.
I wanted to be able to quickly connect a batter charger or air pump, so I hooked up a pigtail w matching connectors directly to the battery. The power socket came w bullet connectors, so I made a pigtail for it.
Radio Shack Interlocking Connectors 274-151 & 274-154
The original connector on the battery charger didn't match the radio shack parts, so I replaced it.
The loose conector in the pic is a spare which serves as a protector for the pigtail connector to keep it clean.
Last edit: 08 Aug 2013 10:28 by martin_csr.
- jbalet666
07 Aug 2013 19:56
amazing help as always martin
i have the same compressor as well
how quick does this drain the battery?
or do you run the bike as you use it
81 650csr
AoA
AoA
- Motor Head
07 Aug 2013 21:28
I've been using the Slime Top Up Compressor for several years. Works good as just that, a Top Up. It is not recommended to run it for extended periods as it will overheat. In the instructions it states this.
So saying that, I run mine, bike off to adjust air pressure in tires and suspension. I carry 3 of the CO2 cylinders and the tool for them, plus patch kit and tire plugs. If you had a flat, on a tubeless tire and needed to get it seated back on the bead. That compressor probably would be hard pressed to do it. Carrying the CO2 is a piece of mind. So far I've only had to use them on the dirt bike.
- jbalet666
07 Aug 2013 23:50
i see ive never used it to fill anything substantial just bicycle tires
ive seen the co2 ones before but never tried them
any suggestions in brand? i know slime makes one and so do alot of other bicycle part companies do but im assuming theres a differnce between those and a motorcycle one correct?
81 650csr
AoA
AoA
- CoolerKing
08 Aug 2013 08:44
I just picked up one of these:
www.amazon.com/Battery-Tender-081-0069-8...onnect/dp/B0041CDPQO
It's a female cigarette adapter that plugs into my battery tender pigtail. Since the battery tender line already has an inline fuse all you have to do is plug it in.
I haven't used it yet but plan to run a GPS off it.
1978 KZ650-C2
1976 KZ400D-3 (sold)
- Motor Head
08 Aug 2013 09:05This is the one I have, which takes the Non Threaded cylinders. They are much cheaper than the threaded ones. Walmart has the cylinders next to the air rifles real cheap.jbalet666 wrote: i see ive never used it to fill anything substantial just bicycle tires
www.rockymountainatvmc.com/p/43/-/171/72...16-Gram-CO2?term=co2
08 Aug 2013 10:42 - 08 Aug 2013 10:43I've only used the slime top-off pump once, as a test. After deflating the rear tire to about 20 psi, the pump aired it back up to 36 psi pretty quickly. Out on the road I'll probably do it w the bike running - it would be a real drag to get a tire aired up but not be able to start the bike because of a dead battery.jbalet666 wrote: amazing help as always martin
I only expect to use the pump in an emergency situation in which I have a slow leak, just so I can limp home. Or if I can do a plug repair without removing the tire & if the tire is completely flat, I'll do as MotorHead mentioned & run the pump for only short periods of time, airing up the tire in increments so that the pump doesn't overheat.
Last edit: 08 Aug 2013 10:43 by martin_csr.
