Right Blinker Works Left Stays Solid?? HELP
  • afotion
  • afotion's Avatar Topic Author
28 Jul 2013 16:47
#598725
Hey guys anthony here,
Unfortunately I dropped my bike today I thought the bike was on the stand which it was but I guess not all the way.
She tipped and fell but no damage other than now my rear blinker light doesn't work on the left side.
Also when I switch it left the front blinker stays solid and so doesn't the light on my gauges.
When I switch it right it works normally and fine on both lights. All other lights work too.
What happened?>
81' KZ750 LTD
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
Re: Right Blinker Works Left Stays Solid?? HELP
28 Jul 2013 17:06
#598729
Assumed all else is as it should be. Your problem is a broken or burned out turn signal lamp. And since the fromt lights up, the problem is the rear. Easy fix. Let us know how it turns out. Paul
  • upncummr
  • upncummr's Avatar
28 Jul 2013 17:11
#598731
You can swap bulbs between the left and right sides and see if the problem follows the bulbs. If it does, then it's definitely the bulbs.
  • MFolks
  • MFolks's Avatar
28 Jul 2013 18:01
#598739
Front bulbs should be #1157"s (dual filaments)for turn and running lights, with #1156 for rear turn signals.
