Fuel and Oil light
- Spectre1982
Fuel and Oil light
23 Jul 2013 18:48
Today I was out riding the 750 when the oil and fuel light kept going on and off intermittently. Also, the tach wasn't responding correctly and was jumping around from 3-4000 rpm. The bike was still running fine when all this was happening. It only flashed for about a minute then cleared up. I didn't see that happen again for the rest of the ride. I'm going to check and make sure all the electrical connections are tight. Anybody know if I should look at anything in particular?
Thanks
Thanks
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
1978 Kawasaki KZ200
- Spectre1982
Re: Fuel and Oil light
23 Jul 2013 20:32
Both the oil and fuel light flash on simultaneously like when you first turn the key on. Had to make another run and it started doing it again. I'll look at it tonight.
1978 Kawasaki KZ200
1978 Kawasaki KZ200
- dbc92s10
23 Jul 2013 21:17
I had the same issue ended up the ground cable was loose on battery good luck
81 ltd1000
1135 mtc 10.5/1
cavanaugh racing head
38.6/32 p&p
APE k410 cams
APE hardware and tensioner
84 gpz1100 trans
kerker w comp baffle
rs36 carbs
fast by gast race crank
1135 mtc 10.5/1
38.6/32 p&p
APE k410 cams
84 gpz1100 trans
rs36 carbs
The following user(s) said Thank You: Spectre1982
- Spectre1982
23 Jul 2013 21:31
Should have been the first thing I checked. Both terminals were a bit loose. I'm sure that was it.
Thanks
Thanks
1978 Kawasaki KZ200
1978 Kawasaki KZ200
