New electrical connectors the same as stock?
  • martin_csr
  • martin_csr's Avatar Topic Author
21 Jul 2013 16:01
#597570
No eBay APP ID and/or Cert ID defined in Kunena configuration1981 KZ650-CSR .... Igniter connectors
Are there any new electrical connectors that match the stock connectors?
Specifically, for the Igniter on the 81 650-CSR. Z1Enterprises, EasternBeaver, & OregonMotorcycleParts, etc have various connectors, but I don't know if they mate to the connectors on the stock wire harness. Thanks.
Here's the Igniter.
  • martin_csr
Re: New electrical connectors the same as stock?
23 Jul 2013 09:41
#597845
Someone at Z1Enterprises said the Kawasaki connectors are proprietary & that their connectors do not match. I found a motorcycle page that lists the measurements of the same connectors, and the ones I need appear to be the same as the stock connectors on my bike, in size & shape. So we shall see.
There were some inexpensive HEI ignition modules on ebbaayy, so I'm going to try making the homemade igniter from the info posted on loudhvx's motorcycle stuff page . My stock igniter is functioning, so I'm not going to cannibalize its connectors which would be the easy thing to do... that is if the new connectors don't match.
  • MDZ1rider
  • MDZ1rider's Avatar
23 Jul 2013 13:38
#597897
Try this guy.
www.vintageconnections.com/
The price list has pictures that may enable you to find the connector you need.
Be patient if you have a question and don't get an immediate response. It's a part-time small garage business run by an enthusiast.
  • martin_csr
24 Jul 2013 11:08
#598044
Thanks. I saw those. The stock igniter has two 4-pin connectors - 1 large & 1 small. The red one at VintageConnections et al looks the same as the small one but no one seems to have the larger connector. I thought the K&L B18R was the same, but its locking mechanism is different. Something else I'm not sure about is the wire gauge. The terminal pins for the red connector are 22-18 AWG - I don't know if 18G would be correct for the application? I haven't found the wire gauge size for the K&L terminals, but I'd guess they are the same (22-18 AWG).
