correct size fuses
  • GregZ
  • GregZ's Avatar Topic Author
correct size fuses
11 Jul 2013 19:01
#596050
Never needed fuses but I do now. Where can I get the correct size fuses. OEM little shorter then the regular auto parts store fuses
The following user(s) said Thank You: trianglelaguna
Re: correct size fuses
11 Jul 2013 19:15
#596052
Be sure to check Pep Boys and Radio Shack. I can't remember where I got mine, but I think it was one of those places. Ed
  • MFolks
  • MFolks's Avatar
11 Jul 2013 19:27
#596054
The fuses are AGX in size, smaller in length, but the same diameter as a AGC fuse. Auto parts stores might have them, and boating supply stores too.
  • Sorf
  • Sorf's Avatar
12 Jul 2013 05:38
#596126
Like these?
Click here
  • boatdrinks
  • boatdrinks's Avatar
12 Jul 2013 08:22
#596134
Z1 enterprises has them for sure.
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
  • sig
  • sig's Avatar
17 Jul 2013 23:29
#597027
I use oversize fuses with no trouble. With the same volt and amp rating all you have to do is make them fit :)
O'rileys auto parts carris the 20amp fuses, but these old fuses are all in short supply
1982 KZ650H CSR
