Is the dana Ds2-1 the right part for my 82 ltd1000
- otistmp
11 Jul 2013 09:17
and how does it install and adjust
Re: Is the dana Ds2-1 the right part for my 82 ltd1000
11 Jul 2013 10:48
Is there something wrong w your stock ignition? The Kawasaki electronic ignition is supposed to be very reliable. The coils & spark plug wire set are what usually need to be replaced.
- Cynjut
11 Jul 2013 12:31
Second that - in fact, that's exactly my experience.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
- otistmp
11 Jul 2013 23:01
i have been told that the the stock is not adjustable advance and retard
- Motor Head
11 Jul 2013 23:08
True in its as shipped state. But you can change it manually.
Why do you need to change the advance curve, have you built a performance engine?
The Dyna S won't give you an adjustable curve either, you need a Dyna 2000, and then there are 4 curves to chose from.
- otistmp
11 Jul 2013 23:35
yes stage 3 jets k&n air pods, vance and hines pipes and you can get better low end power with the adjustments
- Motor Head
11 Jul 2013 23:39
You can change the Factory set up real easy. You can open/ slot the screw holes where the plate bolts on. You can try different springs for the weights, even shorten the throw of the weights, drill them or add material. Its just like having a a old distributor, but with a Very Good electronic system.
