No rpm/speedo lights
  • GregZ
  • GregZ's Avatar Topic Author
10 Jul 2013 19:16
#595873
77 kz1000. I have the idiot lights but both clocks nothing. I pull the the rpm gauge out bulbs are fine. no power
Any suggestions before I have to tear the gauge cluster and headlight off
Re: No rpm/speedo lights
10 Jul 2013 19:43 - 10 Jul 2013 19:43
#595881
That is very weird. Assuming it is stock, the wiring for lights in the speedometer and tach are in the same little harness as the lights for the turn signals and idiot lights. You may want to test the pins in the connector feeding the lower end of the little harness (see arrow) to see if you have power there. Keep in mind, that you'll need to figure how many pins should normally have power (i.e. turn signals normally won't unless flashing). Ed
Attachment 00000_2013-07-10-2.jpg not found
Last edit: 10 Jul 2013 19:43 by 650ed.
10 Jul 2013 21:31
#595894
More info....
The part number for the meter wiring harness (shown as #11 in diagram above) is the same for the KZ1000-A1 as the one for the KZ650-C1. Below is a blow-up of the section of the KZ650-C1 wiring diagram that shows the colors in the harness and the one feeding it. The blue wires to the meters should be the hot ones; black/yellow normally are ground. Using that info may help you see if you have power at that 9-pin connector. Ed
Attachment 00000_2013-07-10-3.jpg not found
  • GregZ
10 Jul 2013 21:54 - 10 Jul 2013 21:56
#595904
No power. Also no power at the 4 pt plug behind the left side cover
Last edit: 10 Jul 2013 21:56 by GregZ.
10 Jul 2013 22:03
#595906
On the KZ650-C1 that circuit comes off a 10amp fuse. Have you checked all the fuses carefully using a meter? I ask because sometimes the little metal caps on the glass fuses loosen up and break the circuit even though the filament is ok. Also, when you turn on the headlight do the front running lights (in the turn signal lenses) come on? I ask because it appears they are powered by the same circuit. Ed
  • GregZ
10 Jul 2013 22:32 - 10 Jul 2013 23:12
#595912
There is no power going into the fuse red/blue to brown. With headlight on, no running lights via blinkers.
By the wire diagram this seems to be link to the right hand switch yes/no? I did send off the right hand switch to my buddy who disassembled paint and put back together.
From the owners manual.
The head, tail and meter lights come on if the switch is pushed forward to the ON position with the ignition switch in the on position.
oh boy
Last edit: 10 Jul 2013 23:12 by GregZ.
10 Jul 2013 23:57 - 11 Jul 2013 00:03
#595930
I think you may have pretty much found it. In the KZ650-C1 diagram below (and your bike's switches may be very similar) notice that circuit controlled by the headlight switch branches into 2 circuits at or very close to the switch (I put a red oval around the branch). One of those 2 circuits goes to the 10 amp fuse that powers the running lights and tach/speedometer lights. I would try to find where that branch connection is and see if it's hooked up. Ed
Attachment 00000_2013-07-10-6.jpg not found
Last edit: 11 Jul 2013 00:03 by 650ed.
  • GregZ
11 Jul 2013 00:14
#595934
Thanks for all the help. One more thing. Can you post a photo of that complete wire diagram. I am trying to red the little one in back of owners manual.
cheers
gregz
11 Jul 2013 00:20
#595937
Included in KZr FILEBASE:
www.kzrider.com/filebase/doc_download/267-z1000a1
Good Fortune! :)
11 Jul 2013 12:40
#595992
Be sure to use the diagram Patton provided as it is specifically for the KZ1000-A1. The sections I provided were form the KZ650-C1 diagram, so there are differences, although I believe the general layout of the meter harness to be similar. Ed
  • GregZ
11 Jul 2013 21:19 - 11 Jul 2013 21:22
#596068
Todays update. Nothing new. Worked on them all afternoon. Electrical issues suck. Plus slammin cold beer all day doesn't help. I pulled headlight again. plugged in a complete set of z1 gauges and turned key woo-la I have gauge lights. Preceeded to pull my gauges off replace all four bulbs plug in nothing check wires install. I'm done with it. As long as I have hi/low ,blinkers taillight fine with me
One other thing. Bad memory but I'm sure I replaced front indicators with better chrome. Bike was a barn find so prolly old indiacators rusty. front bulbs are single filament and duel filament will not fit. Little prongs ore offset if this bike should have them for running lights. Make since ?? i'm drinkin
All I know is a real Kawasaki should be delivered here in a few hours. screw these kz's Z1's baby
Nabbed another 73
Time to go back out to the garage drink beer and smoke some cigs
Last edit: 11 Jul 2013 21:22 by GregZ.
  • RonKZ650
  • RonKZ650's Avatar
12 Jul 2013 01:00
#596115
They run these T joints for power and/or ground throughout the harness. They are basically just one wire in, then a crimp to two wires, so two wires out. These can and do break and one leg gets no power or ground. You can dig in the harness to find the culprit, but easier just to see what you are missing. If you are missing power, parellel a single wire from a good point of power, if you are missing ground, parellel a single wire to a good ground. Bypass the stupid T. Not a concours resto type repair, but a quick and easy bypass without breaking open the harness.
