Blinky no blinky
  • lucienmaier
  • lucienmaier's Avatar Topic Author
Blinky no blinky
09 Jul 2013 14:39
#595697
So I had this all working a couple days back. but my left blinkers work good. but when I switch to my right my headlight and tail light blink. Not even a week ago both sides were working fine. I figured something is bridged somewhere. but wanted to check with all of you.
--1981 Kz1000m CSR--
--Converted to 1100CC---
  • Cynjut
  • Cynjut's Avatar
Re: Blinky no blinky
09 Jul 2013 14:46
#595699
That's odd. I'm gonna guess you lost the black/yellow wire to the headlight, but that's probably wrong, since the tail light is involved....
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
  • MFolks
  • MFolks's Avatar
09 Jul 2013 15:40
#595711
Here's the color codes, get a multimeter and start in the headlight housing & then check the wiring in the handlebar switch pods, as they are starting to suffer failing solder joints.
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
  • lucienmaier
09 Jul 2013 22:03
#595754
thanks much!
