Building wire harness-what size wire?
- kzz1king
08 Jul 2013 00:13
What size wire do I need for my barebones wiring ? Thanks
Wayne
Wayne
Home built KZ1000 turbo setup
- MFolks
Re: Building wire harness-what size wire?
08 Jul 2013 00:53
Lights and turn signals, are usually 18 gauge in size. Others may be 16 gauge, with some as large as 12 gauge(depending on the circuit) Battery cables(due to their size) are usually 8 gauge, but for better current flow, maybe 6 gauge.
Go to www.easternbeaver.com for connectors and other wiring needs.
Here's crimper information:
www.pbase.com/image/93309736
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
For quality wires. go to where a washer or dryer is being scrapped out, as the appliance wires are flexible, and usually two or more colors on the wires.
HEADLIGHT
