new coil blows main fuse
- dkoz
07 Jul 2013 00:09
Hi guys..
I put new dyna 3 ohm coils and 7 m plug wires..
Now it pops my main fuse as soon as power is applyed.
I did not see a + or. - ..on the coil primary..
Spacer is touching screw at primary lead
It looks like all other pictures I've seen..
Any help??thanks
Any help??thanks
Attachment 1373166395416.jpg not found
Attachment IMG_20130706_220736_080.jpg not found
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
1978 Z1R D1
1978 A2
- Motor Head
Re: new coil blows main fuse
07 Jul 2013 00:12
You have to make a nylon spacer, you can't use the metal one like that. Go to the hardware store and get a couple nylon spacers, cut it to length, and reinstall. Problem solved.
The following user(s) said Thank You: dkoz
- dkoz
09 Jul 2013 20:41
thanks for the spacer advice...
no more blown fuses :
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
1978 Z1R D1
1978 A2
