no brake light or head light
  • vrdash4
  • vrdash4's Avatar Topic Author
05 Jul 2013 00:58
#595110
[IMG
not getting any power to the head light and the stop light come on only if i turn the key to parking lights. Any ideas?
I did just mount up a led tail light
1980 KZ 650
  • bountyhunter
  • bountyhunter's Avatar
Re: no brake light or head light
05 Jul 2013 03:11
#595115
Did you install a new ignition switch? That's what happened to me. The new switch wasn't wired the same as the old one. :blink:
  • daless
  • daless's Avatar
06 Jul 2013 01:13
#595253
I'm sure you double checked all the connections you had to mess with while installing the LED. Triple check them. Also make sure nothing else around was disturbed, and don't forget about the fuses.
Did the connections match up wire for wire when putting in the new light? Somehow, somewhere, there's a break in that circuit. Gotta complete it.
'77 KZ1000A1 - Mikuni VM29s, Kerker 4-1, K&N pods, LTD mags, Z2 seat
  • vrdash4
06 Jul 2013 08:37
#595263
the neutral safety switch wasn't plugged in
1980 KZ 650
