no rear tail light.
- asevans
no rear tail light.
30 Jun 2013 19:02
Hi,
I have no power going to my rear tail light.
My brake light works, just not my tail light.
I have power running through rear fuse and going to the reserve lighting box. Then no power coming from box to rear tail light. I have ohm tested the wire from reserve lighting box connector to the rear light and it is good.
it must be that something in the reserve lighting box is bad.
has anybody ever taken this box apart. i took it off the bike and started to take it apart then stopped. thought i would ask here before i destroyed it.
thanx
Aaron
thanx
Aaron
1976 kz900 Mostly stock
1978 Z1-R Project
1978 Z1-R Project
- MFolks
Re: no rear tail light.
30 Jun 2013 19:20
The reserve lighting system only works with the headlight, switching from low beam to high(at a reduced voltage)so's not to blind oncoming traffic.
I'd replace the bulb with a known good one, and then voltage check the bulb socket(s) some bikes have dual tail/running lights.
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
HEADLIGHT
- asevans
01 Jul 2013 02:21
the colors are correct for the tail light. brake light circuit works fine. ground is good. my wiring diagram shows red wire coming from the reserve lighting assembly.it must be tied in to the headlight in the reserve lighting terminal assembly, so the taillight comes on when the headlight comes on. i guess i got to take it apart to see whats going on in there. i have power going in and have power to the headlight.nothing on the tail light.
thanx
Aaron
thanx
Aaron
1978 Z1-R Project
1978 Z1-R Project
