Aftermarket Igntion for 83 KZ750 LTD
- 2ndgenKZ
- 750 LTD
28 Jun 2013 19:07
What System should I look at or what are you running???
1983 Kawasaki KZ750 LTD MAC
1983 Kawasaki KZ750 LTD BONES
1981 KZ750E KERKER
1985 Dodge Conquest FLATTY
1995 Jeep Cherokee RUSTY
1981 KZ750E KERKER
- steell
Re: Aftermarket Igntion for 83 KZ750 LTD
29 Jun 2013 12:20
Why do you want to replace the stock electronic ignition? Stock is better than any aftermarket ignition on a stock motor.
29 Jun 2013 12:39steell wrote: Why do you want to replace the stock electronic ignition? Stock is better than any aftermarket ignition on a stock motor.
+1 My understanding is that the stock electronic ignition system works as well as or better than aftermarket systems and requires less current. Ed
- 2ndgenKZ
- 750 LTD
29 Jun 2013 14:46
thanks guys, staying with the stock coils. was going to go DYNA b/c I thought it was an upgrade. dude I bought the bike from had cut cylinder 2 wire way too short. just replacing wires.
1981 KZ750E KERKER
1981 KZ750E KERKER
- MFolks
29 Jun 2013 15:09
Your stock ignition coils were marginal, even when new, add years of cooking under the tank, and they develop cracks, letting in moisture, shorting out the coils. A popular upgrade is the 3 ohm Dyna or Accel ignition coils. If you go with new coils, replace the metal mounting spacer next to the terminals with a plastic or nylon one, as the primary(small wires) can short out, blowing the fuse).
Both Dyna and Accel will be using 3/16" ring terminals, replacing the 1/4" push on type that came with the Kawasaki ignition coils. I'd imagine the RED insulated 18 gauge terminals will work.
Some good information about using proper electrical crimping tools:
www.pbase.com/image/93309736
