electronic ignition with clutch safety?
- asevans
26 Jun 2013 17:02
78 z1r.
it has the clutch safety starter switch.
i followed the directions and no problem.
there is a black wire that comes from the starter relay that plugs into the coil and ignition. couldnt figure out where the clutch switch plugs into. it shows on wiring diagram that it goes into black wire to starter relay. well its all taken up with new electronic ignition.
Is all i have to do is get a different connector to connect this black wire with ignition and coil wires?
anybody else put in an electronic ignition with clutch safety?
thanx
Aaron
thanx
Aaron
1976 kz900 Mostly stock
1978 Z1-R Project
1978 Z1-R Project
- loudhvx
Re: electronic ignition with clutch safety?
26 Jun 2013 17:49
The clutch switch is for the starter circuit. The ignition is not affected by the clutch switch.
Power for the ignition comes from the kill switch. The power for the starter solenoid starts from the kill switch, to the start button, through the clutch switch, then to the solenoid. You can just connect the two clutch switch wires together to bypass that safety.
Later models did have a safety kill for the ignition, but that was based on the kickstand switch and neutral switch.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- asevans
27 Jun 2013 16:11
Got it. I'm ready to fire.
Thanks
Aaron
Thanks
Aaron
1978 Z1-R Project
1978 Z1-R Project
