starting problems
  • Amboray
  • Amboray's Avatar Topic Author
starting problems
25 Jun 2013 22:27
#593938
I have a 1981 kz1100 a1 that has been running great up until this last month in which i have had some issues getting the neutral light to turn on when i turn the key. If this neutral light does not turn on my bike will not start. I had noticed over the past month when i inserted my key and turned it I would have to spend time trying to find that "sweet spot" with my key so the neutral light would come on.
I'm no mechanic, but I was wondering if i replace the ignition switch would this solve my problem?
Any advice would be appreciated!
Thanks
Re: starting problems
25 Jun 2013 22:40
#593940
I think you're correct. I seems likely that the reason the neutral light isn't on is because the ignition switch isn't making a good connection right away. Then once you find the sweet spot all is ok. I don't know if the ignition switch can be opened up to see what's wrong but it may be worth a try; it could be just a dirty contact or something of that nature rather than the switch worn out. Ed
  • sig
  • sig's Avatar
25 Jun 2013 23:26
#593951
In my 650 that can't be opened :( but aftermarket ignitions are available new for around $40 on e bay
1982 KZ650H CSR
  • Motor Head
  • Motor Head's Avatar
26 Jun 2013 09:25
#593987
Depends on the switch yours takes. Emgo makes a new one, but the other one is NLA. So also I believe you can remove and disassemble, clean the contacts. I've done it when needed on a few including my K2 which has a similar switch.
See if it looks like this one. www.z1enterprises.com/ItemDetails.aspx?i...lock&item=EM40-80610
