Bottom of the ignition lock blew
  • ggenovez
  • ggenovez's Avatar Topic Author
18 Jun 2013 22:01
#592965
Hi all,
I was trying to start my kz1100, when I noticed the oil/neutral light would not kick on. I could move the key back and forth, but no love.
SO I took out the headlight and noticed under the key mechanism a bunch of wires were sticking out.
Looks like the bottom of the lock ignition mechanism fell out. I have all the parts and was able to get her turning by putting the plastic and little brass pieces in their place.
Any idea how to secure the lock/ignition/cable/connector back?
Thank you,
George
KZ-1100 A1
  • Motor Head
  • Motor Head's Avatar
Re: Bottom of the ignition lock blew
18 Jun 2013 22:08
#592968
I believe it just snaps together, there are Tabs on the black plastic. If you remove the main part of the switch, 2 allen bolts, you should see the Plastic Tabs. If they are broken. You might be able to epoxy it, and use it till a new switch arrives.
The following user(s) said Thank You: ggenovez
  • ggenovez
18 Jun 2013 23:27
#592985
Seriously? clips? that's all that holds it??? Glad it didn't happen while I was on the road.
So what is the part called so I can order a replacement.
Thanks
KZ-1100 A1
  • ggenovez
19 Jun 2013 00:01
#592990
Also, I thought I was lucky and had all the internal parts, but it looks like one of the springs is missing.
Any idea where I can get a replacement?
KZ-1100 A1
  • Motor Head
19 Jun 2013 09:43
#593033
www.z1enterprises.com/ItemDetails.aspx?i...lock&item=EM40-80610
Make sure its the same, as it looks like there are 2 choices, according to kawasaki.com
  • ggenovez
19 Jun 2013 10:04 - 19 Jun 2013 10:04
#593039
Thanks Motor Head,
Mine actually looks like this one
KZ-1100 A1
Last edit: 19 Jun 2013 10:04 by ggenovez.
  • Motor Head
19 Jun 2013 10:22 - 19 Jun 2013 10:26
#593042
That is the hard to find one. Part #27005-5019. There are of course lots of places that List the part, but I doubt they have it. NLA from Kawasaki. So to find a New one might be hard. Ebay currently doesn't show one, but one could show up there as New Old Stock/ NOS.
Ask the Guy's at z1enterprises to see if they know a supplier, or another switch that might work in its place.
Here is the link to the parts fiche at kawasaki.com: www.kawasaki.com/DefaultFrame.aspx?strCo...81%26SHOWVEHTABS%3d1
You can see it fits a few different models, by clicking on the ? when viewing the part #.
Last edit: 19 Jun 2013 10:26 by Motor Head.
  • ggenovez
19 Jun 2013 10:37
#593047
Thanks Motor Head,
Well, since the electronics and lock is good, and it's only the selector and plastic tabs that's bad, is there any NOS locks I could use from a different model and just replace the broken parts with?
I'll ping Z1 as well.
Thanks.
KZ-1100 A1
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
22 Jun 2013 01:55
#593472
1982 KZ1100-A2/1170 sleeper 😀
The following user(s) said Thank You: Motor Head
  • Motor Head
22 Jun 2013 12:01
#593489
daveo wrote:
Thats a Sweet Deal!
Better do the Buy it Now, as it says 1 person per hour is viewing it.
