Replacing Stator - Help Please
- RbK
12 Jun 2013 15:34 - 12 Jun 2013 15:35
Hey everyone, I'm new to these forums but I was wondering if anyone had any advice about replacing a stator on a 2000 Kawasaki Ninja EX250F. I have everything taken apart but the service manual says I'll need special tools. Is there anyway around that and if not where could I get my hands on these tools?
Thanks in advance, :laugh:
Ryan
Ryan
Last edit: 12 Jun 2013 15:35 by RbK.
- turboking
Re: Replacing Stator - Help Please
12 Jun 2013 16:01 - 12 Jun 2013 16:02
you need to go to ex250.org it's a 250 ex forum.... you might get an answer here. :dry: I myself own and 2001 ex 500 .... great little bikes
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
Last edit: 12 Jun 2013 16:02 by turboking.
- turboking
12 Jun 2013 16:07
and to answer your question if the oem manual states you need special tools (puller ,etc) you can usually order aftermarket...... otherwise you may do more damage....... my .02
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- RbK
12 Jun 2013 16:08
Yeah, I've been posting on a few forums. A friend directly me to try this one too. These are the tools it states I need if any one can help, thanks.
Rotor holder: 57001-1222
Rotor puller: 57001-1216
Rotor puller: 57001-1223
- turboking
12 Jun 2013 16:17
if you are talking about the stator itself .....it should unbolt from the cover, easily removed..... the rotor will need a puller...... :pinch:
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- turboking
12 Jun 2013 16:20RbK wrote: Yeah, I've been posting on a few forums. A friend directly me to try this one too. These are the tools it states I need if any one can help, thanks.
motion pro more than likely sells the puller...... you can use a strap wrench to hold the rotor if needed..... you will need an impact , electric or air
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- turboking
12 Jun 2013 16:21
pullers usually sell for around $25 way cheaper than the kawi tool. :huh:
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- turboking
12 Jun 2013 16:28
Dennis Stubblefield Sales Flywheel Puller - 18mm x 1.5-R.H., Internal, Male - MP18
available at dennis kirk for $12.99, shows 3 available
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- turboking
12 Jun 2013 16:33
and which puller you need depends if your rotor is threaded , male (I.d.) or female (o.d.)..... :pinch:
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- turboking
12 Jun 2013 16:37
may I ask why you need to remove the rotor?
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- turboking
12 Jun 2013 16:46
If it's a charging problem, the rotor rarely goes bad , usually the stator, wiring or regulator/rectifier..... :woohoo:
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
