82 GPZ1100 no power to pump and starter - help
  • jcote75
  • jcote75's Avatar Topic Author
08 Jun 2013 02:15
#591298
Hi,
I've been working onthe bike this winter and did remove te headlight so did disconnect all connectors.
I've just finished reassembling everything but now the starter won't turn when i push on the start button and the fuel pump doesn't load with I put the key switch on...
Anyone one could give a clue to where to start searching for the problem?
i've check all connectors in headlight and everything is ok. All light, speedo, and other accessories are working. I can jump start the starter on the solenoid and it turn...
Thanks for your help
Joce
  • Motor Head
  • Motor Head's Avatar
Re: 82 GPZ1100 no power to pump and starter - help
08 Jun 2013 11:20
#591317
Make sure your handlebar Run switch is working. It has a yellow/ red wire and a red wire. Then there is also a switch at the clutch lever, and a switch at the side stand for the starter to work.
"File Base" has your wiring diagram. ;)
www.kzrider.com/filebase/doc_download/263-kz1100b2
  • jcote75
08 Jun 2013 14:48
#591328
Wires were cut on the run switch.
Thanks for the help
