Starter issue
  • treitz
  • treitz's Avatar Topic Author
Starter issue
07 Jun 2013 23:55
#591290
This isn't on a KZ but you guys are smart so I figured I would start here.
Finishing up my brothers cx500. Had it running just fine, the. Suddenly no start.
Heres the weird information that might help diagnose the problem... When I push the starter button, the headlight turns off!! I don't know what this means, but it might be important.
Could be the starter switch?
Could also be the starter solenoid. Do those just suddenly go out?
1979 KZ400 - 2-1 Manifold - Mikuni VM34
  • MFolks
  • MFolks's Avatar
Re: Starter issue
08 Jun 2013 00:46
#591293
Have the battery fully charge, and then take it to be load tested(most motorcycle shops, and some auto parts shops will do it for you).Check the battery cables for corrosion, as all must be clean and tight for maximum current transfer. Check the Negative cable from the battery to the engine mounting bolt too, as most people forget to look at it.
I noticed that www.z1enterprises.com is offering 4 gauge battery cables. These will carry a lot of current vs the stock cables which I think were undersized for the electrical load.
  • treitz
Re: Starter issue
09 Jun 2013 14:39
#591464
Bad solenoid. Had a backup, put it on, all good.
  • jeanpaul
  • jeanpaul's Avatar
Re: Starter issue
10 Jun 2013 09:34
#591570
The issue must be resolved as quickly as possible...
bat shaving
