80 kz1000 kicks battery issues please help
- Xspecsx
03 Jun 2013 12:50
Bike runs great, kicks over with kick start even though battery is dead as a door nail. I charge the battery and a couple days later its dead again. am I going to end up chasing wires or could this be something like a stator issue? any insight would be greatly appreciated.
Jerred Kincaid
Tattoo Artist
The Holy Mackerel
196 Forbes Ave
Saint Paul, MN 55102
Tattoo Artist
The Holy Mackerel
196 Forbes Ave
- MFolks
Re: 80 kz1000 kicks battery issues please help
03 Jun 2013 14:01
It sounds to me, you've got a drain on the battery. Do this: take a 12 volt light bulb, disconnect the Positive battery connection, and place the light bulb(you'll need a socket and wiring to do this),and see if the light bulb come on. If it does, start pulling fuses to determine which circuit is causing the drain. One or more wires may have damaged insulation, causing circuits to be energized that should not have been.
The following user(s) said Thank You: Xspecsx
